PC makes sound when Num Pad pressed
Lysrin
Nova Scotia
Simple question, is Numlock on or not on when it beeps? Some programs will beep if you press an invalid key and if numlock isn't turned on you could be pressing an invalid key for the program.
Definitely a shot in the dark but worth asking just in case. Not trying to insult your intelligence! ;)
Do you get the same behaviour with a different keyboard?
Lysrin
Nova Scotia
There are some things in that article that you can try. Is the issue that the computer continuously beeps, or only when you press a num pad key?
ZZLEE
KANATA
On start up screen look fore helper aids programs turned on.
Edit: Ease of acses
mr.joy
Member
USA
Russell, you can disable the beeps by holding the NumLock key down for a little more than 5 seconds. Here are where the setting for Toggle Keys are kept. Go into the Control Panel's Ease of Access Center and uncheck Turn on Toggle Keys.
Ta-dam!
