PC to LG tv through hdmi connection issue Please help
rsw309
New member
I have an hdmi cable and i am usually able to connect my pc to my tv using this cable. But the last time i tried to do it the picture on my tv comes up slanted and distorted. But this works on my other tv so i know it is not the cable or the PC. maybe it could be a resolution issue or something of that sort. Any advice or help will be greatly appreciated.
Laptop
Intel Core i3-2330M [email protected]
4096MB Ram
Intel HD Graphics 1696MB 1366x768 (32bit)(60Hz) Display mode
TV
  • Screen size: 50-inch class (50 inches diagonal)
  • Resolution: 1920 x 1080 (1080p Full HD)
  • Dynamic contrast ratio: 3,000,000:1
  • Brightness: 1500 cd/m2 (candela per square meter)
  • 600Hz Sub Field Driving: Yes
  • Built-in tuner: ATSC/NTSC/Clear QAM
  • Audio output: 20 watts (10W x 2)
  • Speaker system: 2-way, 4 speakers
  • Dolby Digital decoder: Yes
  • Surround system: Infinite Sound
  • Input labeling: Yes
  • Swivel stand: ±20 degrees
  • VESA compliance: 400mm x 400mm
  • Warranty: 1 year parts and labor; 2 years on the panel
Connections
  • HDMI (version 1.3, HDCP): 3 rear, 1 side
  • Component: 2 rear
  • Composite A/V: 1 rear, 1 side
  • RF: 1 rear
  • PC input (15-pin, D-Sub): 1 rear
  • PC audio input: 1 rear
  • Digital audio output: 1 optical, rear
  • USB: 2 side
  • Ethernet LAN: 1 rear
  • RS-232c input: 1 rear
rsw309
New member
Lowering the resolution on the Laptop or the TV and no im not sure what the overscan feature is...
CMetaphor
Quadfather
Montreal, Canada
Lower the resolution of the laptop.
Overscan is a feature provided in some graphics card drivers that allows you to "scale" or change the size of a PC image on a TV screen (in laymans terms). However, setting this too high can sometimes cause the visual corruption youre seeing.
One last thing, make sure youre TV isnt set to stretch or zoom the image too much, that may be affecting it as well.
rsw309
New member
i have fixed the slanting problem and the image is visible by changing the aspect ratio on the tv from 16:9 to 4:3 but now the image on the tv is skinny using only about 60% of the actul screen.
