PC won't detect monitor via motherboard
ryant71
Member
Update:
I went into bios and enabled multi-monitor but I have a new problem, my pc is now using the intel onboard graphics and not my Nvidia Graphics card :(
Any idea what to do?
\/ Old part of thread \/
Hi folks, since getting this pc I have not been able to connect a monitor via the motherboard, it only seems to detect the monitor via the graphics card (Which I have only just noticed)
I noticed this as I was wanting to duel screen but ran into the same problem as last time, the what I now know (I think!) to be the motherboard VGA slot doesn't detect the monitor.
Graphics card is a Nvidia GeForce GT 630
When poking about in settings I saw this, which leads me to believe my main monitor (The dell one as seen) is actually connected to the graphics card.
KaptCrunch
Ontario
motherboard model ? and revision of MB not bios version
is the second moniter known working?
and does MB have graphic port?
ryant71
Member
Not sure what you mean by the bit in bold.
Model: P8H61-MX R2.0
Second monitor is known to be working.
Not sure if the mb has a graphics port or not.
KaptCrunch
Ontario
revision means that manufactor made same model # of MB but used different chips supplier
that's the reason of Rev: note R2 in model name
now if use a rev1 bios on a rev2 MB = DOA, door stop, brain dead system
also look on MB for printed Rev: x,xx to verify before any bios update
I noticed that bios version current 1106 for P8H61-MX R2.0
useASUS AI Suite II to update bios and check drivers are up to date
P8H61-MX R2.0 manual.pdf
<NAV class=row>
  • yes it does have onboard gpu 1 x DVI 1x VGA rear I/O
Multi-VGA output support : DVI/RGB ports
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
need to go in bios settings Advance/onboard devices
auto, and enable multi-monitor
ryant71
Member
Thanks so much for all that information, I have managed to get it working now.
Very helpful and informative :)
Shadowmeph
How did you get it working, I remember I had a similar issue with my asrock board and it ended up being a simple fix but of course I don't remember what I did :haha:
ryant71
Member
