PC won't turn on
elimtl
** nvm was too excited and plugged the power sw into power led pins noob mistake** all good now
just got a new pc.
evga g2 750 w
krait 3x gaming mobo
phanteks p400s case
corsair led 16gb ram 3000mhz
corsair hydro 110i v2
i7 6700k
gfx not arrived yet
i assembled everything.
I see a orange light for the LAN connection
i press power on the case but nothing happens
no fans are on
psu fan is not on
nada
double checked all my cabling seems fine
i got the 24pin in, i got the 8pin in for cpu, i got 1 sata for my case LED and for the ssd, i don't get it.
Either i am overlooking something or maybe the case is problem?
help :(
wirerogue
since there doesn't appear to be a power switch on the motherboard, try shorting the 2 power pins on the motherboard with a small screwdriver. it only requires a momentary connection to start.
