Wasn't really planning on making a post, but I figured why not since Lysrin had come across it on Swiftech's site to use Pinesol to clean their AIO's, I've started giving it a shot on my stuff too.
Sadly I didn't take any before picture, but this Swiftech bay reservoir was super stained from UV Blue Feser One. Why it got so stained, I don't know, I can only suspect that the acrylic used wasn't polished/smooth enough or this is just a poorly designed reservoir. Basically the whole reservoir had a blue haze to it, with the highlighted sections being the worse build ups.
I had started with maybe a 25/75 mixture (Pinesol to water), ended up closer to a 50/50 mix. Let it run with the pump for roughly 6 hours, and then let it sit over night for about 8 hours with the pump off.
Granted, I know I didn't take the best pictures here either, but I've highlighted the sections as they progressed over time.
Definitely a lot cleaner than it was, not 100% perfect, and I'm not too certain if running it longer will remove that last bit or not. Due to the design, it's kind of a "dead zone" which doesn't get much flow regardless of what angle/position I put it at.
