KaptCrunch
Does motherboard have a working speaker, so you can hear it beeping.
Not even one from another PC? Fair enough. Just be sure that the one it replaces (the whatever in there right now) isn't some weird form factor that can't be reused if you decide to change the case. As long as it's a standard ATX PSU it'll be useful in almost anything. Or, you know, use it to test and return it? Hah.
I can hear beeping sound when it first startup and no was heard when it hangs on black screen
Ah ha! You didn't mention beeps! Check out your motherboard manufacturer + the number of beeps you hear. Beeps = motherboard isn't completely dead. So there may be some hope still (don't buy the PSU yet). The beep code *could* point towards ram or GPU issues. So check it out and get back to us.
Hmm. So a single beep would and Should mean everything is okay. But you still see *nothing* on screen? Tried different monitors? Check monitor inputs? Different GPU? If your motherboard has an onboard GPU you could try that without the add-in discrete card, but I don't think that one does. All you can really do is strip back parts and swap parts.. which is much more difficult if you don't have spare parts.
Yup when i turn my PC on, it either goes into desktop and hang on black screen after less than 5 minutes or it just hangs on black screen without it even booting into the desktop. I think my monitor is working fine as when it hangs, my keyboard is not responding as well. By that i mean the caps lock key and num lock is all not responsive
And if possible, pictures or videos of what you see always help too in these sort of cases.How about you describe absolutely everything you know about the problem so far and we'll see if we can narrow it down more with all the details in front of us.
