Plex server build questions.
Shadowarez
Folding Team
Arctic Canada
i built a new system for plex and can tell ya a amd ryzen 3200g is not enough dang thing runs full tilt so much so the media it serves laggs. turn plex off cpu isnt pegged at 90-100%
ill try again with the 7980xe see if plex soaks up all the cores in that.
clshades
Big White Ski Resort
That doesn't sound right. I've run Plex on an Intel 6600 no problem. I don't doubt your prowess with computers tho. I wonder if it's the internal igpu that can't keep up or the cpu itself? Or does that cpu have an internal GPU?
Shadowarez
Folding Team
Arctic Canada
yeah it has a vega 8 gpu built in. i just thought of this i wonder if its defaulting in plex on windows to that setting make my cpu hurt.
crazyea
Surrey, BC
with a 3200g you should be able to do 3 streams of 1080p x264. If you are using x265 than it may not be enough. AS for the igpu last I heard plex doesn't support amd hardware transcoding. Could be different now. IDK.
EDIT:
Windows
  1. Windows native (DXVA2)*
  2. NVIDIA Decoder (NVDEC)
  3. software decoder (libavformat)
Shadowarez
Folding Team
Arctic Canada
yeah ill see if disabling the hardware acceleration works as i know plex works with cuda not open cl.
anabioz
Montreal
I'd recommend nvidia cards for hardware transcoding (encoding), in particular P2000 or newer:
NOTE: Nvidia recently increased max con-current streams from 2-3 for non-pro cards.
crazyea
Surrey, BC
Aren't they generous.
djbrad
Emby supports hardware decoding / encoding on my 2400g, no problem with x264 / x265 10b. I would be surprised if Plex does not support it.
