FreeKnight
What's people's experience with polishing acrylic like? More effort than it's worth?
The Barrow GPU block I have is pretty good, no obvious mill marks though the sides and fitting mounts are definitely that 'frosted' look. Debating if it's worth getting this thing to a glass like finish. Disassembly looks pretty easy, it's one o-ring for the card and only about a 10 screws to remove the fitting mounts and led strip.
