It was worth a shot...One of my cats has been over grooming his belly and more recently not peeing in litter box. He went on some NSAIDS for a while and expensive af food. But still having trouble getting him back to using litter boxes.
So I tried clay litter again for first time in almost 3 years. I hate it. It's hard to clean, so messy, dusty, smells like cheap perfume, and you use about 4x as much. But it's clear the cats prefer it as the use it 10x much.
So I had an epiphany, or so I hope. Using the strong small totes from PA. I had drilled hundreds of holes in one to use to sift the pellets. Threw down some fine steel mesh screen. Then in the container below, fill with pellets.
If my plan works, liquids will drain through to bottom pellets. Then pellets will break down instead of the clay clumping. Thus being much easier to clean and not using near as much clay. Really hope my genius works out.
EDIT: does seem like my genius in fact does not work.![]()
We are currently using the "lightweight" litter from walmart (special kitty brand I think). Not using it for anything to do with it being lightweight, but it just seems to clump/hold better, which means we can go a lot longer between full dumps of all the litter pan. Doesn't stink/break apart/dust like the others we have tried.
