power
clshades
Calgary
have you tested all the pci-e power ports on the psu with the with both sets of cards? I'm not really sure how you are figuring this stuff out etc.
WolfBane
new bruinswick
i drained my system and installed 2nd lower card in the first slot and nothing ...
so i redrained system put first card back in top slot and BAM worked great !
so i am pretty sure now that the bottom card is bad , i sent evga a request for a rma , still have 378 days left on warrenty .
So now i am waiting on a RMA number , hopefully by tomm :)
WolfBane
new bruinswick
Ok got myRMA # Now to pack and ship to EVGA in Cali....... :) Wunder how good they are at replacing things ???
KaptCrunch
Ontario
when you get card back, have a digital multi-meter to check pcie power plug for correct polarity by pinout
may have mixed MB power with pcie
bottom image is the correct for pcie for some PSU are not marked on plugs
10e
Markham, Ontario
There's a BIOS switch on those cards. If one BIOS is corrupt, you can switch to the LN2 or non LN2 bios on the cards.
It's in this image on Hardwarecanucks:
http://www.hardwarecanucks.com/foru...x-780-classified-review.html?no_redirect=true
Just scroll down to the image with the dual 8-pin PCI-E power connector image and you can see the little slider switch that can change it from LN2 to non LN2 bios. It obviously should only be done when the PC is off.
MARSTG
Montreal
The tech specs on corsair website say this PSU has 4 PCIE connectors not 2. After all is a 750W. I had a 650W that was having 4, so it would have been a bit lame for Corsair to showcase only 2, on quite a high powered PSU on single rail design.
10e
Markham, Ontario
I'm not sure. I just viewed a bunch of unboxings and they all had 6+2 x 2 on each modular cable, so maybe I'm wrong, or I may have had a CS750M instead.
Wolfbane, why are you saying you don't have dual 6+2 pin PCI-E connectors on each cable? I'm very confused right now.
If you're having trouble finding the right cables, I think these cables said "Type 3" on one of the connectors, usually the one that goes into the PSU's modular connector.
