Pricecheck trade-up for EVGA 560ti
Ottawa
for 570 depending, the card you have is registered I am assuming and warranty isnt transferrable? If that's the case, if you get a 570 from giga, or say msi that do not need to be registered and you still have warranty on them then at least 100, if you are getting a 570 that also has non transferrable warranty then I would say 70-80. I wouldnt trade a winner with ati cards, as no offense the 6000 series suck, all i hear is bad things about them:( stick with the winners, stick with the green machine!
Edit: though the card you have is a top of the line 560ti so you may get a bit more value, but I dont know if someone would downgrade and not ask for at least 100 bucks. i know I wouldnt!
supaflyx3
Langley, BC
I would only consider a 6950 if it's shaders are confirmed as unlocked.
I'm hesitant to go ATI because i wouldn't be folding anymore.. but they do seem to beat a 570 while consuming less power.
Ottawa
well unlocked shaders hmm thats a bit different. however, check out 570 vs 6950
AnandTech - Bench - GPU11
570 beats a 6950 in most cases and yes its a power hungry card, but it also doesnt have issues with the drivers!
I just think AMD/ATI offer good value, but you get what you pay for. i liked the 4890 tho, it beat out a 280 in gaming, but not on paper.
