Problem with Mic on skype and other VOIP software
Kentalish
Member
Qualicum Beach, BC
Hey guys. I am having this huge problem that is annoying me and my friends.
I talk to them on skype a lot and i have windows 7 64 bit and im using an onboard soundcard from the intel x38 bonetrail motherboard
When I am playing games people hear what I hear as if im broadcasting but I am not. same goes for youtube or music... people have told me to go to my sound options and go to levels and mute the mic.. but there is no mic located anywhere
http://img208.imageshack.us/img208/5836/soundy.jpg
and when i go to the mixer there is nothing either http://img51.imageshack.us/img51/3789/mixerg.jpg
mic boost makes it worse for people.. but if i dont have it on then people cant hear me. im using a SteelSeries Siberia Full-size Headset with the clip on mic it comes with...
I have never had this problem before.. it just started happening this month..
I hope someone can please help me it gets really annoying sometimes
Thanks
ZZLEE
KANATA
Are you plugged into rear mic
sound should be fore" front mic" fore haedset. My sister had same problem with vista and scype. select front mic in sound panel
