Problem with my EZDebug LED VGA light
rovalo
New member
Good afternoon,
im having a problem with the EZDebug LED VGA light from my B250M Msi Motherboard.
I have sent it to my seller RMA and they said it didnt have any problem and that they had updated the BIOS from it.
The problem is that my screen a ASUS VG248qe doesnt find the vdi connection either from my boars or my gpu.
Done several things to fix it but didnt worked.
I have my desktop since december and after six months that problem appeared.
Hope you can help me out cuz im out of solutions atm.
If you need more specs from the build hit me up!
sswilson
Moncton NB
Do other monitors (or your TV) work with it? Have you tried a different cable and/or port?
rovalo
New member
Have tried vdi and Hdmi on gpu and board, going to try on my tv. I went to a pc store and guy told me the problem is from the board. Will reply with my attempt on my tv.
