program for reading bios info on intel?
sswilson
Moncton NB
For S939 there were several programs which would read the enhanced memory settings off of the bios. Is there such a thing for intel chipsets, or was the on-board memory controller of the A64s just easier to access?
sswilson
Moncton NB
Those look like exactly what I'm looking for. Thanks!!!!!
I don't want them to set timings from in windows (I'm always afraid of finding a setting that isn't affected by a c-mos reset.... :) ), I just want to know what the current settings are @ auto so that I know where to start from bios.
Do you have a preference between the two? (memset looks like it works with the p965 chipset).
Eldonko
Calgary, AB
Memset is easier to work with, systool can cause some instability if you try and tweek the wrong setting.
