Push/Pull Static Pressure/High CFM
Shadowarez
Arctic Canada
I'm looking to add 3 high static pressure fans to my 900D it will Exhaust from the Corsair H150i ProI'm not sure if the case will have enough clearance if I use my Noctua NF 12s so I was also looking at slim fans any help from the experts will be greatly appreciated. I'll be using this cooler only till I get the EK 360 Extreme Kit. Then I'll rebuild with new fans.
Shadowarez
Arctic Canada
An I just add 3 NF12s to help Exhaust also I'm seeing worrying reports about the 150i Pro were and what size washers can I safely use in case mine has same issues since I've been told this is 7980Xe requires a AIO of some type.
