Putting Cables Back in...
AmuseMe
Age
27
Saskatoon, SK
I got tired of taking one cable out at a time while sleeving a PSU and just took all 24 pins out to get it out of my way. Well, they are out and I am just double checking that this is how they go back in:
Just follow this and I should be good?
SugarJ
Langley, BC
That's correct, but my Strider has a fully modular 24 pin cable. If you didn't take both ends off the cable you can simply run pin 1 on one end to pin 1 on the other, and so on. No need to check the charts.
AmuseMe
Age
27
Saskatoon, SK
Thats how I did my Strider 850W. This one is 1000W (also a strider) but I completely removed the cables first... :doh::doh:
0o0
Toronto ON
I use that green tape, stick one piece on the 24 connector and cut up small pieces to stick on every wire and number then accordingly. works great after I dye the cables all black (if it's not modular)
AmuseMe
Age
27
Saskatoon, SK
Urgent: I was running late and couldn't fully start the computer, but I pressed power for the first time. I made it to the post screen and the one that says "ASUS P7P55D". I than turned off the computer because I was in a rush to get out the door. Does this mean that the cables are back in their right spots? If they where not 100% right, would I even have gotten this far?
Zero82z
Montreal, QC
You probably got it right, but if you screwed it up, whether or not the PC will POST depends on how badly you did.
AmuseMe
Age
27
Saskatoon, SK
im actually on it right now just going through a test drive and getting drivers. Must mean that I did it fine. Everything is detected under the Manager, and the CPU overclocked like a charm (he wanted it OCed)
jtf2
a cheap psu tester is your best friend,or at least check each line with a meter to see if it reads the right voltage
