Q6600 overclock to 3.0 GHz
Hermes¡¢
Hey guys,
When my computer gets here, I want to be able to overclock it to 3.0 GHz. I got a HDT cooling solution so I am well prepared. Now the only thing is the memory. I intially ordered some Redlines, but they are currently out of stock. I do not plan to go past a 3.0 GHz overclock on my CPU, so which memory is good enough? Would PC2-6400 with latency 4 timings be perfect?
I heard that there is no point in getting PC2-8000+ unless I want to get some big overclocks like an E8400 to 4.0Ghz or a Q6600 to 3.6 Ghz.
Anyways, I am unsure of hat to pick. If PC2-6400 is perfect, then I can get that with tight timings and have overall better performance.
What do you guys think?
SugarJ
Langley, BC
IIRC, the Q6600 has a 8x multiplier. So you'd be at 8x375. DDR2-800 mem is fine.
encorp
IIRC = If I Recall
It's a 9.
I think it's best to go with 1000+ Check out the Mushkin Ascent's either the 8000 or the 8500.
MpG
Kitchener, ON
Even if you don't strictly need the memory headroom, you can usually up the memory divider ratio to run your RAM faster, even if you haven't raised your FSB speed. The real-world benefits tend to be limited, but they exist. But yes, strictly speaking, DDR2-800 would work for your goals just fine.
joeperson
I did 9x333 on stock voltage and some really slow default memory timings. Cheap 6400 will do fine. The only thing that may be a problem would be the stability of the q6600 at a given voltage. I've seen older boards require a little extra vcore to keep things stable.
Hermes¡¢
Alright, with that being said, should I get some top of the line PC2-6400 RAM? Also, is that Corsair memory that comes with the cooler worth it? I might as well also mention: What is the difference between T1 and T2 in memory timings and which is better?
Xilikon
Quebec City
8x400 = PC2-6400 area.
9x333 = PCR-5300 area.
You are fine with a PC2-6400 kit. The Redline is only good if you want to go with high fsb (up to 500) or with asynchronous memory (using a different multiplier instead of 1:1). I'm using a set of Redline myself with my Q6600 overclocked to 3.825 GHz.
Hermes¡¢
Okay thank you for confirming. :) if you have time, could you possibly answer the other 2 questions in the above post?
Thanks.
joeperson
Question 2 of three: No, unless you want to do memory overclocking.
