Quadro Problems
Dr_BenD_over
Fallen Folder
Nova Scotia
Quadro FX 3800, Vista x64, 16:9 ratio monitors.
When you try and select the native resolution (1920x1080) of the monitors, the only refresh rate available is 29 or 30hz. This almost seems as though it's detecting the monitors as TV's. (seems to be a common issue with Vista :blarg:) Anyway is there a refresh override proggy that will work with Vista and a Quadro?
