So, right now I got a single pump inline with my system, and originally I was going to replace it with a dual pump (but not enough space). So now, after I cleaned up some of my tubing, I turned on my rig and for some reason the pump (that was working fine) did not turn on. Luckily I was paying attention to the flow meter, and then after several reboots it turned on.
Anyway, what I really wanted to know is the folloiwing:
Can I have a 2 different pumps in series, and if one fails, will the second pump still be able to drive water through the failed pump (assuming that the failed pump didn't seize up and just decided to crap out because it was lazy)?
