Questions about memtest
shayan288
Vancouver, BC, Canada
Hi,
I'm a complete idiot when it comes to memtests.
I do not know how to run a memtest. lol.
Could someone please tell me how to run a mem test NOT in my OS.
Please help.
Thanks guys.
shayan288
Hi, infiniti,
ty for link but i have seen and read over many times, and i still do not understand it
what i was hoping for is for someone to give me instruction into how to run a memtest not in my OS.
sorry and thankyou for your link.
Infiniti
Vancouver, BC
Okay, I'll post some instructions here.
1. If you don't have a burning program or anything in your system, download BurnAtOnce.
2. Install it, and download this.
3. Burn the image(ISO) onto a blank disc.
4. Make sure your BIOS settings are correct so that it will load CD first over HD.
5. Pop in the disc, restart your system, and the rest should be self explanatory.
Hope this helps, good luck with your problem. :thumb:
shayan288
if i have 4gb of ram do i run 4 tests of 1gb of ram each since that is the limit
and if i do will it scan all my ram on my computer and tell me if it is defective of not
yamawho
Rosemere, Qc, Canada
Well ... start by testing all the sticks.
DRAM speed, timings, voltage are all factors when testing.
Your setting the speed to auto and the timings by SPD should give you stock settings.
Make sure have the correct settings in the bios and if your not sure, confirm using cpuz while in windows since memtest doesn't always give you the info.
