Gallery Quick NCase M1 V3 w/Fury X Gallery
Vittra
Ontario
Beware - not all of the cables in the short cable kit are actually short. I remember that between the stock STSF45-G and PP05-E cables, some of the PP05-E were larger. 24 pin in particular for sure.
zoob
Toronto, ON
Short update. Swapped my HTPC back to a FuryX after having a 980Ti in there. Much more room inside with the short card and distance from the computer means I don't mind the slight pump noise still present in the new version. Also plugged in a DP1.2 to HDMI2 adapter and happy to report that 1080p 120Hz works fine.
