Rad screws?
AmuseMe
Age
27
Saskatoon, SK
Depends what radiator your using.I use 30mm ones for my hardware labs black ice sr1s
JD
Toronto, ON
Beware that some radiators use M4 rather than 6/32. Depends if it was manufactured in the USA or not I guess.
sswilson
Moncton NB
Yeah... my EK rad was M4.... pain in the butt to find sufficiently long screws so I ended up securing to the rad with the bottom holes (short screws) and then securing that to the case/fan grill with standard case fan screws.
JD
Toronto, ON
These are a godsend:
Radiator Mounting Screw & Nut, 25mm - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
Radiator Mounting Screw & Nut, 38mm - Water cooling systems, pc liquid cooling kit, cpu, video card, hard drive
My rad is the XSPC EX240 Dual Thin Performance Radiator, does this help?
That's 6/32, so you're fine :)
You can just go to your local home improvement store and get 6/32 screws no problem. I think it's 1-1/4" length that you'd want for 25mm fans.
It's funny how Canada uses the metric system and yet it's damn near impossible to find metric screws in the major chain stores.
