RAID headache
Bubbzilla
EDMONTON AB!!
I have 2 old 500 gb harddrives and I want to use them to get my feet wet with raiding. I think I underestand the idea behind raid, but I have no idea hoe to actually make it work. I read the chapter on raid in my mobo manual, and followed the steps, but when I was done, it turned on, filled up with a bunch of text about harddrives, then loaded like normal. but when windows was supposed to start, it went to the the screen that lets you choose what mode to start in. I choose start normally. It came up with the vista loading bar, flashed blue then restarted. It looped like that until i trying the boot repair on the vista disk, which did nothing. Then I went back into the bios, and disabled raid. this fixed it, but i didn't get anything out of it. I am still raidless.
I should mention that I dont want to instal an OS on the RAID till I know it can be done, and till I get windows 7. No point reinstalling everything only to do it again in a month.
After i had restored normallity, i started rooting around in the vista disc manager. It should my 2 harddrives as unallocated space, and when i right click it gives the option to create a striped volume. If I understand right this means RAID correct? Anyway, I clicked it, added the 2 hdds and set everything to default. then I said go, it came up with an "are you sure" window, I said yes, and then it said
The dynamic discs are not supported by this opperating system.
All I want to do is create a raid, that will let my save files to it. Am I doing something wrong? Is it possible thats its a problem with the harddrives?
Please post any thoughts or tips you might have. I am new at this so im not really sure what im doing.
Thnx.
Jake_HT
Calgary, AB
You need to install your RAID drivers... you can use this tool, and make your own custom install of vista including your RAID drivers (and do many other useful things)
vLite - Windows Vista configuration tool
Windows 7 will probably have them. I didn't need to do that to install 7 for my RAID :thumb: did for XP/vista, though
Bubbzilla
EDMONTON AB!!
Cant I just download this driver from somewhere and install it?
Does the driver come on my gigabyte disc?
I dont want to reinstall vista. Infact, I never want to install vista again. The next time I install an OS will be when I get my ssd and windows 7. but im holding off till boxing day.
