Raid setup utility not showing up at boot
odis172
Ottawa, ON
So i originally posted on the asus forums.. and theyve been absolutely no help.
Whats going on is that i cant get into the raid utility to define the array. Asus p5n73-am, supports 0,1,jbod. Using 2x 1TB green drives. ( i know greens arent recommended for raid, im just going to screw around with it) nvidia 610i sb. I flashed to latest bios. Switched from ahci to raid, and set ports 1 and 2 to be raid enabled. (also tried 2-3, 3-4) Yet no option is popping up after post. Tried mashing f10 and holding it down. After all this, i did notice that mediashield rom is popping up for about 1/10 of a second, its extremely hard to see and i never noticed it b4. Tried disabling quick boot, and enabling floppy seek. Only 2 ideas I have left are, bad raid controller and board needs rma, or the green drives arent agreeing with it. Thanks!
AdoP
Guelph/ Toronto
You should know that in general 1tb WD drives have problems with raid0 when used with another 1Tb drive. Something about a built in controller not allowing it in the caviar blacks but I am not sure about the greens.
1. Give this a try, switch your HD sata cables to your onbaord SATA jacks from the intel sata's.
2. Turn on your pc with the HD's connected to the onboard sata's (not the intel sata's) enter bios and switch the intel SATA bios setting to RAID
3. Now boot up and enter windows and reinstall the intel raid driver I think it is ICH10
4. Shut down, switch your HD's back to the intel sata's
5. Restart and let windows boot, windows should identify your drives
Now you should be able to build your raid array, it worked for me.
licked_chips
New member
I'm just now setting up RAID 1 on my P5Q - with dual WD Caviar Green 1 TB drives. Also found I couldn't access the RAID setup utility. Finally succeeded by hitting tab during bootup to get into extended POST. You should see it go through drive detection if you make it in. During drive detection you can hit Cntl-I to get into the utility. It accepted my drives and set up a RAID 1 volume across the pair with no problems.
Now I'm just trying to sort out how Win 2k8 Server Data Center Ed. treats the volume - it appears in Disk Management as a simple single disk with all RAID options disabled on the disk....
