Raja Koduri of AMD fame (less so at Intel) is joining SanDisk's advisory team on High Bandwidth Flash technology. According to the article, HBF is aiming to put a lot of flash memory on the GPU. SanDisk's own press release is aiming to put 4TB of flash memory on a GPU. Let's hope it's cheap enough for consumer GPU later down the road.
www.tomshardware.com
Raja Koduri's mission to deliver high bandwidth memory for GPUs has taken a turn that could enable 4TB of VRAM on AI cards — joins Sandisk to advise on SSD tech that could feed AI accelerators
Sandisk has appointed Koduri to its HBF technical advisory board as an inaugural member, alongside Professor David Patterson.
SanDisk's new High Bandwidth Flash memory enables 4TB of VRAM on GPUs, matches HBM bandwidth at higher capacity
Equipping AI GPUs with 4TB of memory.
