ram overclock
Tazer-[X]
Terrace, BC
How would I go about to squeeze 66 mhz or so out of a set of ddr2?
What settings need to be changed in bios to make it happen?
1Tanker
Ontario
Your post is very vague...please elaborate(RAM Brand, Speed and timings/vDimm..as well as mobo/CPU..).. and i promise you will get replies like crazy.:biggrin:
Tazer-[X]
Terrace, BC
Kingston HyperX pc8000 dual channel ( 2 x 1 GB )
speed is @ 800 Mhz
timing = [email protected] volts
mobo Ga-x48-ds4/q6600 stock
I want to get the ram up to 1066 speeds, which it is rated for 1000 mhz, but it registers as 800 atm.
1Tanker
Ontario
For what reason? You'll find very little difference in anything from 800 to 1066
Sorry...but your post is still vague. 2.3 vDimm should irradicate any issues...but that RAM should run 1066np..your cooling/vCore has more to do with it...Don't fret though.... 1000/1066 won't make any noticacable difference.:biggrin:
enaberif
Calgahree, AB
You should NEVER ever have to run memory at 2.3v EVER.
I don't even recommend 2.2v .. 2.1v is about as high as I would recommend.
1Tanker
Ontario
I concurr
I concur eaberif...yet 2.1-2.2i.sh yeilds extrordanairy results,,,,and u know that.......check this . :bleh:Sorry.enaberif...i'm drunk as a skunk... and you know that there are exceptions....:whistle:
