Random BSOD
implosion222
AB
Can somebody look at my minidumps if I upload them? I'm at lost right now other than having to format again.
Here's a link to the dump file : 010312-9921-01.dmp
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA80082444E0
BCP2: FFFFF8800FE4EAE4
BCP3: FFFFFFFFC000009A
BCP4: 0000000000000004
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\010312-10530-01.dmp
C:\Users\Kevin_Gaming\AppData\Local\Temp\WER-15069-0.sysdata.xml
Read our privacy statement online:
Windows 7 Privacy Statement - Microsoft Windows
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
That's what I'm getting. I thought it was my socket drivers but no nice.
I'd appreciate any help.
thanks.
bissa
Kelowna BC
did you happen to catch the main error code on the bluescreen? that will tell you a lot more (or at least it did in my case) than the event viewer info.
also, what were you doing when it crashed? gaming, benchmarking, stresstesting, browsing, something else, nothing?
these things will help immensely.
implosion222
AB
Thx for the reply!, When it crashes, I dont get a bsod actually, the screen goes gray then the computer restarts . It failed to load the OS twice then I unplugged the computer and plugged it back in. Loaded in windows then got in the bsod error msg. I crash usually when I play Bf3.
implosion222
AB
Looks like it's related to my video card drivers. I'll clean them out tomorrow after work and install fresh ones see if that does anything. I was sure I had installed the most recent ones tho. Hope the card isn't bad.
