random file name generator?
Mr. Friendly
British Columbia
my folks have a lot of pictures with duplicate names that are not the same. are there any tools out there that can go through a folder and give them different names?
trying to amalgamate and sort/delete these so we can start a proper back up system and such.
searched on Google and it gave mes stuff for online file names and jazz, but that's not what I'm looking for. :blarg:
JD
Toronto, ON
If you just want to append random numbers, PowerShell would suffice?
Code:
Get-ChildItem *.jpg | ForEach-Object{Rename-Item $_ -NewName "$(Get-Random)-$($_.Name).jpg"}
Source: https://superuser.com/a/304700
So if you have mypicture.jpg, it would become 1777702880-mypicture.jpg as an example.
If you Google "delete duplicate images" there's some tools that do that as well. No idea how trustworthy any of them are though.
danmitch1
I second bulk rename utility. We use it all the time at work, its super powerful. Ive become a pro with it.
attonbitusira
Guelph
Powershell/BASH scripting is the way to go. I'm more familiar with BASH and can say that it is trivial to search across multiple parent directories and their child folders recursively, get the name, and move them to a single folder with logic to append an integer (random or sequential) if a duplicate exists. Depending on how much you care about the original filename, you could also just copy each filename to a new location with an increasing integer. Lots of ways to skin that cat man.
