Mr. Friendly
I HATE PHONE / TABLET TOUCH KEYBOARDS!!! SO FRIGGEN INACCURATE!!! /me rages against the machine...
Not Newegg domains though... they have a ton of tracking elements. If I pull up Dev Tools, I have 124 errors/warnings of things being blocked, mostly by Edge's tracking prevention and DNS, AdGuard extension only shows 31.I am using PfSense and the DNS blocker. But not very aggressive blocking done on it. At least not for generalized ads. Can't find any with Newegg + PfBlocker.
I want to make one of these but then I would have to use one of my Old pcs which uses more juice then necessary, I wished I could use one of my old laptops then bridge ( I think it s called that) my router for wifi, back 2013-15 I used to use smooth wall I think it was called that.I am using PfSense and the DNS blocker. But not very aggressive blocking done on it. At least not for generalized ads. Can't find any with Newegg + PfBlocker.
No VPN.
Just browsing cases.
just make sure you keep your phone handy (or something to that effect)
This is a good thing as your email account is your most sensitive IMO. It's the "gateway" into all your accounts.Google's push to force 2Fa on all accounts has got steam coming out of my ears!!!!
I have an old galaxy core no data plan if I need a new phone it is going to be rough because I cant afford well not actually worth it for me to spend that kind of money for something that I only talk and text with and sometimes use the Kore app for my kodi box, most people out there seem to be and probably are abdicated to there phones.But again... it's so focused on the idea that everybody has a phone handy (and a data enabled one at that). That is not the case for a not insignificant percentage of the folks with google accounts.
Is that a requirement? I thought you could pick SMS codes too (though arguably extremely unsecure). You should also be able to install Authenticator/Authy/etc to generate codes too.a data enabled one at that
