Rants etc.....
Do you also have some sort of vent that stays open then to pull in outside air? Otherwise seems a bit odd to rely just on a bathroom fan to pull enough pressure to bring in air through all the various cracks in a house. Surprised ERV/HRV isn't required out there.
Yes, we have cold air intakes that run from the outside to the furnace room.
  • Like
Reactions: JD
I've bought hundreds of things from Aliexpress over the years. Never really had an issue with receiving goods. Until until maybe 8 months ago. Unless it was shipped by Aliexpress, I haven't received a damn thing. Literally every other item gets lost.
I've had issues with AliE...DHGate has been okay but Temu...never an issue in the 2 years my wife has been buying from there.
Maybe? It's not something I've ever heard of in Alberta, especially given that forced air is the norm out here
A forced air system circulates air within the house, but generally doesn't do anything to bring in "fresh" air to replace the "stale" air. Maybe since the house is older, the poor insulation/air sealing meant that the bathroom fan was indeed enough to pull air in through all the various cracks? I can't really imagine having an "open" vent in the basement in Alberta though, temperatures get way too cold for that to make any sense. There are some electronically controlled ones, but still, you'd be dealing with major condensation issues.
It surely sounds like it was done intentionally though.
Wouldn't be an open vent but a make up air damper.
But having an exhaust fan running 247 makes little sense to me. Especially on newer construction that is less leaky.
Most of the ones here have a damper (like Lowfat mentioned) mine is an insulated one off the furnace IIRC.
Some of the older exhaust fans are explicitly not meant to run 24/7 IIRC they used to recommend being connected to a timer to avoid burning them out. Not sure about modern fans though.
I'm assuming it was an error, bad tech, weird flawed repair by the previous owner or something. I've never seen it in a house in Alberta before.
Either way, it's fixed now, and I just have some central vac piping to finish and I'm basically done until I get drywall downstairs.
Still need to remove CO2, VOCs, radon, moisture, etc from the house though, less leaky houses are worse in that sense unless there's mechanical air exchange.
...then you have something like my old 1950's double-brick bungalo... no insulation... and all the sun from the day heats the bricks which gets released inwards at night. Sitting here sweating after a warm rainy evening even though the daytime high was only about 20C. Probably have to turn on the AC to sleep.
I loved older built homes because of the materials used we used to create a vacuum open a window in the south face and then one in the north creates a mild breeze through the home cools it off or in winter warms it up
yeh...used to be able to do that here at my in-laws, but since they updated most of the windows that open, can't get a draft / breeze going for the life of me...not even with the encouragement of adding a fan to the mix!
