- Location
- Langley, BC
Totally wishing now that I'd said it was some other key.
Plastic tote / garbage bag depending on size and shove in some bounce sheets or baking soda and let sit for a few days and check on it.holy 5h!7 batman! I got my surplus stuff for my bushcraft camp kit and the plastic / rubber / vinyl surplus haversack smells BAAAD! so bad it tainted everything else in the bag and they were all in their own plastic packaging. man alive...
don't use anything scented here due to our son-in-law's MCSS (multiple chemical sensitivity syndrome) so that's a no-go. we'll probably soak it in a high concentration mix of vinegar / water for a while. eucalyptus based cleaning agents do a wonderful job as well, but my wife dislikes that particular one while I do like it.Plastic tote / garbage bag depending on size and shove in some bounce sheets or baking soda and let sit for a few days and check on it.
GOt things from family members from smoking households and depending on the item that was sometimes enough.
A client had a piece of software that was slow to start up because they did the same thing. Each module was 1 by 1. Some modules relied on others to load but some could be loaded in parallel. They actually refused to allow me to fix it properly because they were to afraid of breaking other things.Windows Start Up is dumb! it loads everything one by one, so it's slower than it would be if it used any of my 32 threads my 13900K has. if I launch several programs manually, it finishes so much faster.![]()
I know. what I'm saying is that letting Windows manage it is a slow ass process. it loads them all in a single threaded manner, so one by one....but if I manually tell some of the start up apps to load before Windows gets there, the PC is ready to rock and roll sooner than if I leave it be.You can create windows tasks to start programs up so you don’t have to do it manually.
