RECOMMENDATION: Audio system
lowfat
Grande Prairie, AB
V2 or the original? And sub volume I don't think really exists, usually you adjust on the sub itself? Or do you mean there's no crossover settings?
The NAD 3045 seems a little more interesting (though double the price) since it's a USB DAC as well.
V1, I've had it like 5 years. D 3020 is a USB DAC too. Seems the 3045 is also a headphone amp, 3020 has 3.5mm out and its garbage. With UE TripleFi 10's it sounds significantly worse than my phone.
On every AVR I've had I think I've always had the option to adjust LFE gain. No Crossover either.
KaptCrunch
Ontario
want the thump i use Yamaha home reciever and fiber optic cable , you can adjust all levels with HTR and MS software.18" sub with 200 watt bridged amp driving it.
Talk about bass if want to rattle dishes or is it live or Memorex moment
