Repeditive error A USB device has malfunctioned
eggokio
New member
TORONTO
I have a optern 170 system and 6 usb ports none being used and I get a repeditive USB device has malfunctioned error. I've tried the disconnect power cord and mb battery for 30mins solution as well as the remove all usb entries in
the registry and reboot. But nothing helps, not even formatting and re-installing
winxp or windows vista. I believe the mb is dying and the usb errors is the first sign. Anyone have a idea what to do to stop these errors? Thanks
sswilson
Moncton NB
Did you try disconnecting the case USB connections? It could be that one of them is doing something funky like shorting out....
Other than that, if you've already done a full OS re-install then it's definately something hardware related, and if nothing is connected to a USB port then it's either your motherboard, the connections to the USB headers, or possibly a couple of the pins on the motherboard USB headers shorted together.
