Request: Thermalright Ultra-120 specs
S|nApSE
Active member
Ottawa, Ontario
Hi, I was wondering if someone would be so kind as to give me an idea of the width of the case needed to house the above mentioned. I was reading the specs on it and noticed that it was almost 16.5cm in height! Does this include the heat pipes? With a 20cm case - not even subtracting the thickness of the case walls and the gap of space between the motherboard mounts and the distance from the top of the processor to the bottom of the motherboard - I'm a little concerned about clearances. Provided I'm reading the specs properly, I'd say most people would be hardpressed to find a case that is much wider than my own anyway. Thanks for the future enlightenment.
