[resolved] second monitor plugged in Motherboard not detected?
Brigitte
Member
Canada
So, I'm very proud of myself, my first ever build is completed, I passed all day on this. I had a hard time with wiring and installing the heatsink properly but the computer boot on first try so I guess I managed to do everything correctly.
But... there is always a but eh?
I'm trying to set a dual monitor display. My new 23'' is detected and set as main and working perfectly, it's plugged in the DVI of the HD 7850 GPU.
The second old 19'' monitor (for browsing) has only a VGA plug so I plugged it in my Motherboard (P8Z77-V LK). But it's not detected when I try to detect it in Windows 7 (screen resolution/detect on VGA)
I'm at a loss here, my search on the web turned out only auto detection never what I'm trying to do. My Motherboard should have integrated graphics and VGA support so what am I doing wrong?
Without this little hiccup my installation would have been flawless :blarg: HELP!
Brigitte
Member
Canada
I tried to use it, heck even tried my old one and weirdly none want to plug in, big resistance and none of the pins are bended. Hence why I'l trying to plug directly with VGA.
Why does direct plugging into the Motherboard VGA is not working?
supaflyx3
Langley, BC
Try the other port, the one you tried plugging it in to on the video card is DVI-D and only supports digital.
Brigitte
Member
Canada
Bottom image. The white port (DVI) nothing fits in, not even my adapter that was working fine on my old computer. The blue port (VGA) is the one I am trying to connect my second monitor in. My Motherboard user guide mark those 2 ports as the ones to use for dual monitor, but my VGA cable = monitor not detected in windows 7. Is there something on the motherboard or Bios I have to enable? I saw nothing so far.
Edit: or is it simply that we cannot use on-board graphics AND GPU? All on one or the other only? Could I then plug one monitor to the other?
moocow
Vancouver, BC
Double check your old cable to see if there's a group of 4 pins surrounding the single big flat slot.
It also said that it only support ATI HD 5xxx and 6xxx in the manual so double check with Lucid to see if there's an update. Finally, is your HDD operation in RAID mode and is iGPU turned on in BIOS?
Brigitte
Member
Canada
on my motherboard it's the DVI-D and yes you are right my adapters are DVI-A and that is why I'm trying to use the VGA cables but VGA is not detected. I have no idea what Raid mode is, it affects dual monitor display? IGPU I'm pretty sure I turned it on in Bios but I will double check. I'm just boggled as to why the VGA cable is not detected.
moocow
Vancouver, BC
RAID is a HDD thing but I downloaded the manual and read that it doesn't recommend RAID mode turned on if you're using LucidLogix. Why do you need to use the onboard graphics card for dual monitors? Your HD7850 should support more than 2 monitors so depending on how many DVI ports you have, you can just plug the DVI -> VGA adapter into the second port. Which brand of video card did you buy?
Brigitte
Member
Canada
I bought an Asus HD 7850 Direct CU II 2GB
this is what it looks like, can't plug 2 DVI that is why I'm trying to use the on-board for the second monitor.
Could I plug the VGA monitor to the main one? there is a vga plug.
moocow
Vancouver, BC
Upon closer read of the manual, I don't think you can plug 1 monitor to the motherboard and 1 to the video card. From what I understand is that if you want to use LucidLogix, you either plug it into the motherboard (i-mode) or into the graphics card (d-mode). Also, there was a bug in the LucidLogix software where it won't run with AMD 12.4 driver so get updated drivers. Here is what I suggest:
1. Set your BIOS to use LucidLogix in d-mode as recommended in manual for 3D performance. So iGPU enable and Primary Display to PCIE.
2. Plug that DVI-VGA adapter to the DVI port of your video card and plug into the older monitor.
3. Buy a HDMI->DVI adapter or cable and then plug that to your newer monitor.
I believe the dual monitor mode you were referring to earlier only works if you only use the onboard graphics built into the CPU. Usually, one would completely disable the onboard graphics if he/she is using a dedicated graphic card. However, your board have LucidLogix unless I read your motherboard model wrong. Disclaimer: I NEVER EVER used LucidLogix or have similar hardware as you listed. I'm just making suggestions after reading the motherboard manual and from what I understand from using multi-monitor on a single card.
