Curious to see what people's thoughts are on alternatives to the O11 series of cases...
A couple requirements:
- 140mm rear case fan to fit this: http://www.phanteks.com/PH-D140.html as I'd likely want to re-use it
- Space for 1 HDD
- 360+240mm radiators as minimum
- E-ATX support with lots of room beside as my GB AOROUS Xtreme X570 is all edge-mounted connectors
Chances are I'd probably get something like the Corsair XR7 360 radiator (54mm thick) to use in the front and then maybe the XR5 240/360 (30mm thick) to use up top. Seems like an easy way to get HWLabs made radiators here and they review decently. The XSPC radiators I have today (EX360/RX240) are pretty old.
I've been considering these:
www.lian-li.com
www.fractal-design.com
www.phanteks.com
Anything else I should look at?
- Space for 1 HDD
LANCOOL II - Tempered Glass ATX MidTower Gaming Case
Best PC&Gaming Cases for PC Builder and Gamer. LANCOOL II is the easiest to open the Tempered glass side panels, offer an unobstructed view to the internal components. The Bottom flip shroud panels provide a quick and easy access to PSU/HDD installation.Powerful multifunctional well-crafted.The...
Vector RS Tempered Glass — Fractal Design
With customizable effects, adaptable layout, and interchangeable elements, Vector becomes what you want it to be: The perfect showcase for your system.
Phanteks Innovative Computer Hardware Design
