Return or are these ok?
JD
Toronto, ON
Never used graphite pads before, I would think it might be okay, but for the price that IC is charging for those, I would say ask for a refund/exchange. Supposedly you can buy Panasonic branded ones for far cheaper.
Shadowarez
Arctic Canada
Was going toss em in the duel CPU and server when I move it to a new 4U chassis. But want sure if these are still ok after what looks like someone using them as a writing surface. I could try use some Tim I suppose. These were like $17 a piece.
Bond007
Nova Scotia
Not really sure. Anytime I have heard of people using pads of any type the performance wasn’t very good. That said, I haven’t heard heard anything of those ones specifically. Personally I would go with TIM.
AkG
I would return it. Firstly its mainly hype - they work no better than most TIM and worse than some. Secondly they are a royal PITA to work with (they conduct electricity like a mofo, increase pressure on the socket, etc). Thirdly it is expensive for what it is. Lastly, it is scratched and damaged in transit. Probably wont make a dif... but it may (no idea TBH). IMHO the only time I would use it is if I was swapping out the cooler often. Otherwise... TIM is a tried and true method that is cheaper and 'just works'. YMMV
Shadowarez
Arctic Canada
Ty thought as much I have Kryonaught paste from thermal grizzly on the way wanted give ole Amd server a clean start in new home but yeah these got wrecked. Was looking forward to giving server nice new product. Ty again guys.
