Lets begin with the accessories. You get a USB 2.0 Cable, VGA, Singlelink DVI-I, powercord and a audio cable
The Monitor has a 24-bit 24" AMVA Panel @ 1080p. When sitting directly in front of it, the colors and blacks look really good. The Problem is the viewing angle, Even moving your head 10 cm to the right will cause a contrast shift. Just on the left side there was a tiny backlight bleed, that can only be noticed on black images. Positive, there was no flickering and not high pitch noise when turning down the brightness.
Left: Samsung SyncMaster 2333HD Right:Iiyama
On the lower left you can find the OSD control. The is nothing special about them. Contrast, brightness, sharpness and color settings
Connection wise you get a DVI-I, VGA, HDMI and a 2 way USB hub.
Conclusion: If you want a single monitor to sit directly in front of with really great blacks and a nice color reproduction, this might be worth considering. But as soon as you look at it from a angle it will have a light shift, but this is just my subjective opinion.
After testing it for three days, I decided to send the monitor back and will try the Dell U2414H next.
Video Review and Unboxing
https://www.youtube.com/watch?v=aN0THorh39Y
