RGB controllers... AAARRRRGGGGGGGGG!!!!!!!
sswilson
Moncton NB
Why does every freaking manufacturer have a proprietary controller???? Why didn't I make sure I got a motherboard that had an RGB header???? In the absence of an RGB header... why can't I order a stand-alone hub that would be compatible with a 4 pin 12V RGB fan????
Heh... so here's the deal... the case I just ordered comes with 3X Lian-Li RGB fans that can connect to several different motherboard headers, but apparently don't have any kind of controller that comes with them. Since my motherboard doesn't have a header and both my Hue+ and Corsair commander pro are proprietary I'm trying to find some kind of generic controller that'll allow me to connect and control a "standard 4 pin 12V RGB" fan.....
Any ideas?
sswilson
Moncton NB
How is it powered? I'm assuming I could get the required DC off of a molex? (I ordered one of the cheaper CM ones for now)
sswilson
Moncton NB
So the RGBW, or do they all connect via the phone app and the one with the remote just adds a bit of hands on control?
