danmitch1
- Joined
- Dec 15, 2007
- Messages
- 2,318
Hi Guys, heres some questions for all you handy folks in here.
I bought a drill press attachment for my rotary tool. This one https://www.amazon.ca/gp/product/B00068P48O/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Its for Dremel but it fits my WEN pretty much perfectly https://www.amazon.ca/gp/product/B07FCRH3XG/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
First question, Is there a specific speed that I should use when drilling wood or metal ? Every time I drill, its either too fast and starts to burn the wood or too slow and just doesnt have enough speed to keep going. My regular power drill never has this issue with the same bits.
Second question, Are there adaptors you can buy to convert the rotary tool into an adjustable chuck style bit mount? So that I can use the all the bits I normally use on my power drill, on the rotary?
Last, What kind of jig do you guys have on your drill press to keep your material in place?
Thanks for your responses!
