rtx 3070 hype, my $850 semi-regret. ryzen 2600
clshades
Big White Ski Resort
It's been talked about in many reviews on the 1080p experience with any of the 3000 series cards. You won't see much of an improvement until you get to higher
resolutions. Also, the cpu will bottleneck.
Petee_c
Active member
I upgraded my monitor to a 1440p 21:9 (AOC cu34g2x)monitor, getting about 90FPS in Warzone with the 3070.... interested to see if my FPS goes up once my Ryzen 5600x comes in......
Bond007
Nova Scotia
Use MSI afterburner and check cpu and gpu use in game. Very much game dependent, but if the GPU is less than maxed you will see an increase across the board with a CPU upgrade. If the GPU use is maxed, you probably won't get much better in max fps, but will likely see improvements in avg/min fps (that is assuming the CPU is occasionally limiting performance).
clshades
If you are running maxed out then that's not bad actually. Turn the anti aliasing to 1x. All it does is make things look too soft anyway. Turn off sun spot caching too. Pointless waste of GPU Ram.
If you are trying to play competitively there's no point to running things maxed out.
Coach
Morden MB
How does that compare to your 1070ti? If you slide that old girl in there what is the performance delta at 1440p everything else equal?
