rx 5700xt not working on Core 2 quad q8400
Killerdk001
New member
My Mobo is Intel DG41TY DDR2. The Isssue Is When I Try To Install graphics Drivers It Shows Display Driver Failed To Start And it Is Automatically Switching To Microsoft Basic Display Adapter. Anyone help Please..
JD
Toronto, ON
That's a pretty old system, what's your power supply? Perhaps it's not getting enough power to run fully.
Also what OS version? Did you have a graphics card in it before?
Honestly though, that's a lot of GPU for such an old CPU, you're going to be bottlenecked pretty severly.
Killerdk001
New member
My Psu Is Coolermaster 750w And Os is Windows 10 1903 Build I had Ancient Gpu Geforce 210 Previously
Bond007
Nova Scotia
Agree with the likely problem, as well as the fact that is a very poor balance. Your CPU would probably struggle to load the gpu more than 25%. You're really going to need something a bit more modern.
gingerbee
Orillia, Ontario
ryzen 2000 series parts can be had for a true bargain right now if you want to upgrade cpu+board+ram. just wanted to point that out if you want to upgrade
MvSlainXVII
Active member
Better upgrade the whole PC cause looking at the spec it is very old and even if it ran in the first case then there will be CPU bound bottlenecking meaning that the CPU hold backs the GPU.
