S video isn't working on my Vid card how can I test it?
Shadowmeph
just got my card ( well a newer cardreplacement) back from an RMA but for some reason the card isn't seeing my tv which is plugged in to the s video out so I am thinking that the s video isn't working,but if I plug in my ati card it works but the nvid 285 card it doesn't seem to be working is there a way to test this?
Shadowmeph
Force TV detection enabled?
As a last resort you can put 2 75 ohm resisters on the s-video line, one between pins 4 and 2 and one between pins 1 and 3.
yes Force TV detection enabled
where can I find the 75 ohm resistors and how do I put them on?
Shadowmeph
hmm I wonder if a Scart adapter would work and where I can buy one
sswilson
Moncton NB
Do you get any kind of signal at all? (I'm wondering if there's a NTSC/PAL jumper on the card)
Supergrover
Okanagan Falls, British Columbia
Radio Shack should have them.
You can solder them into the line or you can attach them to the female plug, insert 1 end in pin2 and the other end in pin4. Do the same for pin1 and pin3 then plug the cable in. Then power up.
Shadowmeph
I don't get any signal . even if the PAL switch is on I would think that I would get something on my TV
