Safety Measurement in water cooling setup?
clshades
Big White Ski Resort
Just use the "attach files" button under the text window. (I'm assuming that's not a mod-only function).
Second pic is a repair done New Year’s Eve. Looked similar to the blown manifold though.
clshades
Over filled/heated system, idiot proof it with accumulator that can handle the temp range or repeat for commerance
No. It’s done with expansion tanks. No special fluid will stop expansion in a heating system dude. Not possible and not to code. Filling a system is done via 15 psi fill valve. Systems are protected with a 30 psi relief. When expansion tanks blow the manifolds get worn out over time. Couple years and they will be fried.
KaptCrunch
Ontario
Looks heat or chemical reaction to plastic. Correct expantion done by air for fluid not compressible.
