Samsung SA23A700D 3d glasses?
Ottawa
Hi all,
I just called Samgsung as my doctor dropped these glasses and there is a big crack on them and now they dont work. I was wondering if there are repleacement I can find and or if I can buy generic 3d glasses and they can work? Samsung does not cover 3d glasses under their warranty.
FreeKnight
Edmonton, AB
If you figure out what type of 3D lenses your TV needs/ the type of 3D it uses, you should be able to use any 3D lens of a similar make. My understanding is most are just a polarizing filter in the lens, if that's the case any brand of 3D glasses with the same polarizing filter should work (Be it a 'Sony', 'Philliips' or 'Samsung' 3D glasses).
Others might want to chime in, but I think that's how it works.
