Scrap aluminium
xxsashixx
Member
Does anyone know where I can buy scrap aluminum in the Vancouver area? something like... 2ft by 2ft max sheet. I want to block off the gap between the mb tray and the hd cage of the ATCS840.
On that topic, what is the "best" way to route cables on this case because I have 8 SATA + power and there is a bulge between the sidepanel and the mb tray and it won't close without force, and even then it still bulges.
xxsashixx
Member
Would you think Canadiantire, ones with autoworkshop have some scrap metal? hehe
dustin1706
Aluminum sheet isn't too cheap, nor too easy to find. If you will be painting it anyway, you could just go with some galvanized mild steel used for ductwork. You will be able to find it for cheap at most hardware stores.
