Screen Cleaning solutions
Solace
Anyone have recommendations for screen cleaners, I ask here since Amazon is riddled with fake reviews and its a headache sifting through 5-10$ items. I used to use some generic stuff from OpenBoxes which claimed to be non alcohol based but I personally think its a lie. The stuff was not that bad though.
ipaine
Edmonton, AB
Best I have used is something you make yourself.
White vinegar and water (ideally distilled water) ratio most places say is 1:1. I usually go with more a 60:40-70:30 mix leaning towards the water.
Spray it into a microfiber cloth then wipe monitor. You can spray it right on but just don't let it drip into the bottom of the monitor.
Works better the any store bought solution I have used.
Dwayne
Courtenay, BC
I just use a damp microfibre cloth. No cleaners on it, it does the job on monitors and TV screens alike.
