Set Affinity/Priority with WinAFC
Arinoth
Halifax
I did that and i get this:
I check to see if it changed in the task manager and they were still their defaults
somecanadianguy
somecanadiancity
In affinityinput.txt, set Test Mode to 0:
Code:
# WinAFC Input File
# Lines that start with a '#' and empty lines are ignored.
# Configuration lines include global flag setting lines, and application profile
# lines. These lines can be interleaved in any order. However, the order in which
# you specify the various application profiles matters if a process could be
# matched by multiple application profiles.
# To run AffinityChanger in TestMode (no affinity settings are modified),
# uncomment the line below and specify a value different than zero. To disable
# test mode, set the value to 0 or comment the line below.
# It is recommended that you try the input file in test mode first, after you
# make changes, especially if you are unfamiliar with the syntax.
[B]TestMode = 0[/B]
Forgot about that part in my original post. :doh:
Sorry about that, guys and girls.
Just added it now.
Shredder
Alberta
Another Sample
A sample for a i7-980X plus 4 gpu cores
This will assign 8 specific CPU cores to any folding core type found within the smp folder then split the remaining CPU cores,1 for each GPU core assigned and wraps it up by adjusting the gpu priorities to 1 above the smp core.
C:\YOUR Application path\SMP\FahCore_*.exe := PAIR0+PAIR1+PAIR2+PAIR3 [priority=idle]
C:\YOUR Application path\GPU0\FahCore_*.exe := PAIR4+CPU8 [priority=BelowNormal]
C:\YOUR Application path\GPU1\FahCore_*.exe := PAIR4+CPU9 [priority=BelowNormal]
C:\YOUR Application path\GPU2\FahCore_*.exe := PAIR5+CPU10 [priority=BelowNormal]
C:\YOUR Application path\GPU3\FahCore_*.exe := PAIR5+CPU11 [priority=BelowNormal]
