Setting up iPads for public use; limiting features/apps
bigFOIG
Vancouver, B.C.
How would I go about doing this? I'm going to have about 30 iPads that I'll be setting up for classroom use and I need to limit the features and apps on them so that people can't screw around with the settings. I also have a MacBook Pro if that'll be needed.
JD
Toronto, ON
There is obviously a way since at the Toronto Auto Show this year, there was a ton of iPads on the floor to show car specs rather than the old piece of paper. You couldn't get "out" of their app.
However, since I hate Apple, I have no idea how. There should be something on their development site maybe?
grinder
I read a white paper that some tech posted on how he rigged the iPads for use in a final exam at a school or something. It was basically a mix of locking down the WIFI network and blanking the iPads with iTunes (backup-restore image) between sessions. All of the content was accessed by Safari on a closed LAN (local IIS server or Apache server or whatever).
It's quite simple actually. no internet = no iTunes = no apps.
lcdguy
Folding Team
An undisclosed location
you could use the iphone configuration tool (it works on windows and mac) to create different configuration profiles. However using this would require provisioning them one at a time. If you need to provision the configuration settings wirelessly (wifi or cellular) you would need a MDM solution. Apple has one but it is not as feature rich as the other third party solutions.
bigFOIG
Vancouver, B.C.
I think this is what I'm looking for! Do you think you can find that article for me somehow?
lcdguy
Folding Team
However if you use configuration profiles you can actually remove the itunes and app store so even if there is a network connection they won't have the icons on the tablet.
