Setting up Raid.. Does it matter what sata ports I use?
Yamcha
Calgary, AB
Hi Guys,
I'm a noob with Raid, haven't done it before, would like to give it ago, I have two identical sata hard drives, and I want to configure raid... My question is does it matter what sata ports I use??
BigDogg
Kitchener/Waterloo
Hi Guys,
It shouldn't as long as they are on the same controller. On my Gigabyte UD5 there are white and blue sata ports. Blue for the JMicron controller and White for the Intel controller. Try putting them in Sata 0 and 1 or 1 and 2.
Yamcha
Calgary, AB
Anyone know if I can run raid with AHCI enabled ??
The reason I need AHCI enabled is because I run OSX as my primary OS.. I want the raid for Windows 7.. when I set it to AHCI instead of RAID It doesn't let me boot up into Windows.. gives an error..
Anyone know how I could get this working with AHCI??
gingerbee
Orillia, Ontario
ahci is enabled when in raid mode automatic that's why you can only choose ide,ahci or raid. fyi that's why it's the same drivers.
weather or not osx supports raid ahci is another question.
Yamcha
Calgary, AB
For some reason, when I choose RAID instead of AHCI I cannot boot into OSX =/ I'm guessing its a mobo related issue..
gingerbee
Orillia, Ontario
you have your osx setup in raid0 too?
1. which hd is osx installed too
2. if it's only installed on 1 hd then this is the reason it does not work. because your osx is not in raid0
3. if you want to setup a dual boot radi0 you'll have to back up all your data and start from fresh in raid0
4. this is where things become unclear with me I am not sure what type of dual boot you'll have to setup for OSX to work i don't use apple stuff at all.
p.s I forgot you'll need to get the raid OSX driver
MarshallX
Active member
London
keep im mind this onchip raid solution on desktop motherboards is software assisted. While the controller supports "hardware" raid, its software assisted. For complete OS independant youd need an actual raid controller.
